SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: slk 280 2008 shiftier stock in D and N
Old Nov 8, 2019 | 08:23 AM
wilfredo1956's Avatar
e430, sel400, 560sl
The gear box shiftier does not move to reverse, therefore to parking. No transmission malfunction code, no engine code other than ABS, because an Tire pressure sensor that must be programmed. Transmission change and works perfect in Sport and Comfort. I is a G7 speed transmission. Shiftier was removed and no mechanical problem observed. The yellow plastic handle to unlock shiftier and solenoid at gear box does not works. The metal bar tat connect gear box to transmission could be moved forward and back, showing not being stock. I have disconnected the battery, which is new, with no results. I have followed instructions for Limb mode, using accelerator pedal and switch on position 2 and off, but no results. Almost nobody know what is happening. Looking for same problem, as up today nobody has response with similar troubleshooting.
Old Jan 31, 2025 | 11:14 AM
Aladdinl's Avatar
Just hed that need to replace the shift selector..i was like 300e in portugal used part
