SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: 2007 SLK280 driver door lock not working
Old Apr 1, 2022 | 03:50 PM
Amauri's Avatar
2007 Mercedes SLK280
I have an issue on the driver's door in my 2007 Mercedes SLK280. I took off the door trim for the driver's door, the door lock used to work properly, now the door doesn’t lock when locking with the remote. I can lock the door manually and the door will unlock with the remote and also with the lock button on the dash Anybody got ideas on how to fix this?
Old Feb 5, 2023 | 08:59 PM
weaver7237's Avatar
2007 SLK 350
Did you forget to install the black plastic trim on the door that goes around the door latch? If it doesn't close the door open sensor, it won't lock.
I had same issue and took me forever to figure out what was happening.. Also the window will not roll up all the way if it sees the door as "open" still.
Bryan
