SLK/R171: November Car & Driver SLK350 Review!
interesting...they've even posted the dyno mode...wonder if it does work
For years we've complained about the butt-in behavior of the electronic stability programs in Mercedes-Benzes, which automatically intervene to shut down power and braking when they think your driving needs help. A dashboard switch suggests the program can be turned off, but it can't—it just kicks in at what it sees as a more intemperate level of driving on your part. We were convinced it simply could not be shut off.
Well, Benz lovers, we found a way.
Here's how. To start, turn the ignition key to the first accessory position, making sure the dash display shows the odometer. The SRS airbag light should be on. Press the trip odometer reset button three times rapidly before it goes off. If you do this right, a screen will appear showing a voltmeter. Then press the "up" arrow on the left side of the wheel twice to take you to the "ESP dynamometer test" screen. Using the plus (+) button on the right side of the wheel, select "on." And then start the car. Warnings will appear informing you that the ESP, ABS, and BAS (brake assist) aids are now turned off and you're on your own.
