SLK-Class (R172) 2011-Present SLK200, SLK250, SLK350, and SLK 55
SLK/R172: R172 HID Xenon Conversion - Anyone had success ?
Old Feb 28, 2016 | 07:50 AM
Arthur#'s Avatar
SLK350
I have done this conversion on two Subaru's and a Mazda,with no difficulty.
They had Canbus.
I have just tried an install on my 2012 SLK350 and had to revert back to the H7's.
Initially both HID's worked OK and the improvement is huge, as it always is.
After about a 20mins drive the first one turned off. I stopped and restarted and then neither would come on.
The status display informs me RH and LH Dip Beam are out.
So back in the garage I checked out the two units in situ, with DC from a seperate battery and they work normally.
I dont understand why it worked at all in the first place.
The web is full of comments on Canbus and how to fix it with a 4700uF Capacitor (I tried it and it made no difference).
What I could not find is any technical discussion on how the lamps are monitored, and how Canbus turns them off. Given the H7s draw about 4.5A and the HID is 4.3A it should not see any problem. The peak current at turn on is higher at about 7A for the HID.
Does anyone understand this well enough to explain what is happening ?
I assume someone has managed a successful install - if so what kit did you use ?
Old Feb 28, 2016 | 10:26 AM
AZN Optics's Avatar
SPONSOR/MBworld Guru
I know there are a couple slks using our Morimoto kits and haven't had the issues you describe.
Old Feb 28, 2016 | 10:50 AM
Arthur#'s Avatar
SLK350
Thanks, assuming they are on R172's can you give me a link to the exact product please.
Old Feb 28, 2016 | 11:15 AM
AZN Optics's Avatar
These are top shelf Morimoto HID conversion kits.
5000k pure white: http://www.aznoptics.com/index.php?m...products_id=65
6000k white with a slight bluish hue:http://www.aznoptics.com/index.php?m...products_id=67
Old Feb 28, 2016 | 11:32 AM
Arthur#'s Avatar
SLK350
Thanks for that, I am hoping someone in the UK who has got it working will come across the thread.
