SLK-Class (R172) 2011-Present SLK200, SLK250, SLK350, and SLK 55
SLK/R172: Vivid Racing -- 20% off VR Tunes for SLK350!
Old Nov 14, 2023 | 12:49 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Post Vivid Racing -- 20% off VR Tunes for SLK350!
Looking to spice up your R172 SLK350 this Fall?!
Vivid Racing has you covered with our in-house favorite -- VR Tuned!
Price: $800 $640 (Code VRTBFCM)
VR Tuned ECU Flash Tune Mercedes SLK350 3.5L V6 R172
Why choose VR Tuned?
Your Mercedes-Benz SLK350 3.5L V6 is a load of fun to drive. This roadster is awesome in its power delivery and performance! The VR Tuned ECU upgrade adds more horsepower over stock. With our ECU flash, you are able to gain improved performance on the engine, stock or modified! The biggest difference when you flash your SLK is the overall improvement of the power curve. Your SLK will have much better throttle response no matter what gear you are in, which is a classic point of conversation with this platform. Where your SLK is sluggish off the line, your newly flashed SLK picks up right away -- and pulls harder through the mid and top end RPM range!
Check out our blog on tuning if you're new!
Power Ratings!
Stock Power: 306hp | 273ft/lbs
Tuned Power: 330hp | 291ft/lbs
Options!
Vmax Off
- This is an increase or reduction of the maximum speed limit.
Race Exhaust - This option is for those running full race exhaust systems. (Cat-Delete Req.)
Pops & Bangs - Pops and bangs (burble tune) is the result of an ignition delay which creates an exhaust detonation when the throttle pedal is released. Caution, this process must only be used on vehicles with a full race exhaust. This may affect long term engine reliability.
DTC OFF - This option is to delete Trouble Code (DTC) related to the engine. You provide us the code.
**Some options are not available for different software version of the vehicle. We cannot know this until the factory ECU read is uploaded. If a feature is not available that is extra, we will refund you that amount. We do guarantee to provide you with the best possible performance tune.**
Questions? Connect with the team!
forums@vividracing.com
(480) 966-3040
Direct Email @
tristans@vividracing.com
Extension 239
We can't wait to hear from you!
Tristan Shallow
Vivid Racing
Performance Specialist
(480) 966-3040
