SLK32 AMG (R170) 2001 - 2004: Discuss the SLK32 AMG.
Will 05' C55's rim fit on SLK32??
Old Nov 13, 2011 | 07:42 AM
C55atMAX's Avatar
C55
Smile Will 05' C55's rim fit on SLK32??
Is SLK32 and C55 wheel spec same??
I am trying to sell my stock C55 rims to SLK32 owner.. and i am not really sure whether it will fit or not..
Your help will be appericiated
This is spec for my stock rims
Front wheel width: 7.5"
Front wheel Offset: ET37
Rear wheel width : 8.5"
Rear wheel Offset: ET30
bolt pattern: 5 x 112
Old Nov 13, 2011 | 09:58 AM
320 dreamer's Avatar
2003 porsche 996 turbo
the rear offset is a bit off but i actaully use the exact same wheel dimensions on my 32 with zero issues. be aware im not lowered and the rear is hella flush with the fenderwell lip. if i dropped the car i would hit with every bump.
the front is the same et but 1" bigger diameter no issue. the rear oem is a 35 et and the decrease is minimal on the et but the 1" diameter makes a difference and aslo the tires used. my choice was a factory size front (225/40-18) and a 265/35-18 ) rear in the hankook v12
Old Nov 14, 2011 | 04:19 AM
C55atMAX's Avatar
C55
Thumbs up
so as long as car is not lowered it shouldn't be the problem right??
Thanks for your help~!
Old Mar 15, 2022 | 08:18 PM
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
This is our SLK32 with SLK55 wheels. They fit perfectly but you do need special lug bolts. 12mm thread for the SLK32 with 14 mm ball head for the SLK55 wheels.
I sold our SLK32 years ago but I’m currently looking for another.
Old Mar 16, 2022 | 04:06 AM
cm60k's Avatar
Your bride looks superb..
my friend had 03 R170 SLK320, he swap it with 5.4L,,
really great ride..
-;-ZAYED-;-
