SLK32 AMG (R170) 2001 - 2004: Discuss the SLK32 AMG.
Help with pulley identification
Old Aug 23, 2018 | 04:08 PM
Wayne Mullins's Avatar
SLK32 AMG
I have a 2004 SLK32 AMG with RENNTech R1 Performance kit installed. The idler pulley just above the water pump disintegrated and I'm not having any luck finding a replacement. Apparently the R1 kit changed the idler pulley. Contacted RENNTech and they said the pulley was not changed. It appears that the water pump pulley and the idler were changed to compensate for the larger crank pulley. Any help identifying the correct part number and/or source would be greatly appreciated.
trying to find part number/source for this pulley.
Old Sep 17, 2018 | 11:57 AM
pi_4x4's Avatar
2003 slk32amg
were you able to find your part#? there are a lot of online catalogs like this one:
https://benzparts.autohausofpeoria.c...0pump%20pulley
good luck!
Old Oct 18, 2018 | 04:00 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
that looks like a LET kit. It was sold by LET and then later, eurocharged (and manufactured by ASP IIRC). That pulley (60mm or so) is notorious for failing ... often you can merely replace the bearing (6503). If you need more info or a complete replacement pulley, I can help you out with that. you can send me an email at latemodel21@yahoo.com
hope that helps,
Chris
Old Nov 6, 2018 | 10:29 AM
SLK32 AMG
Found pulley
Was able to get an improved pulley thru Needswings. Thanks for the suggestions
