SLK32 AMG (R170) 2001 - 2004: Discuss the SLK32 AMG.
Looking for...
Old Nov 14, 2022 | 08:35 AM
FlaSLK32's Avatar
02 MB SLK32 AMG
Looking for...
02 SLK32 AMG, SC magnet & housing. New, used good condition, Take off from going to a fixed pulley. Send pics and price. Thanks.
Old Nov 15, 2022 | 10:35 AM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
If you have not already, you should be seeking this out from Srt6 owners as well .... as they are far likely to be making the change to fixed. You might try checking with Jon Bond performance (they used to rebuild these superchargers and stock new and used parts for it) jon@jonbondperformance.com.
What are your symptoms? (if it is damage from oil on the magnet, you may need to do and input shaft seal as well).
HTH,
Chris
Old Nov 15, 2022 | 11:43 AM
FlaSLK32's Avatar
02 MB SLK32 AMG
HTH,
Chris
no symptoms. proactive repair, bearing going.Discovered cracked friction ring on housing after removing pulley. I dont care tp replace entire SC for a bad friction ring. tx for the source!
