check engine light after 2 days of ownership?
My check engine light came on today after 2 days of ownership, has anyone else had this issue and if so, what was the cause?
Car seems to drive fine and dealer said just ignore it for a couple of weeks then he will reset the light.
Most likely it will happen again. Tell your dealer to get a clue.
Too many to list
Originally Posted by E55AMG99
WTF kind of response is that? CEL usually means that the ECU cannot get a correct signal from one or more sensors. When this happens, the engine goes into "open loop" mode which also means poor fuel economy, poor power and poor emissions. His answer should have been, "No problem. I'll meet you in the service bay in 5 minutes with a technician to pull the error codes off the ECU. Then, we'll reset the ECU and see if it happens again."
Yes, you need to check the code with a scanner ASAP. But, there are hundreds of causes for a CEL to come on and most will not cause "open loop" mode or effect driveability. A loose gas cap is a very common cause and it will not effect how the car runs.
Trompazo
