Kleemann Stage 7 dyno numbers
Medeci, yes, got the Kleemann LSD. Trust me, it needs every bit of traction it can get.
Cheers,
-Matt
See ya,
-Matt
Cheers,
-Matt
. Yes, 91 octane as listed in my original post was used for the dyno run. I guess I'll use 100 next time...we can gauge the power benefit from higher octane & my ECU learning...should pull 520 - 540 or so (I'm thinking 520, we'll see I guess
).Your LSD question....if TC was engaging at 80 mph, it ain't going to be like have 345 DRs on the rear at lower speed. Seriously James, next "mod" are rims/tires. See ya.
-Matt
-Matt
My CR is 9.0:1 and i vary from 10.9:1 to 11.5:1, and still get some detonation on 100F days under full throttle on 93 Octane gas.
Hopefully its just the strange way the graph is reporting mph not a/f.
If you get wheel spin @ 80 mph are you getting larger rear rims/tires?
Pirelli Rosso tires have a wear rating of 140 and are about the best reliable street tires i have found.
Please keep us updated as to your driving impressions
PS - putting it back on the dyno next week as well. I'll post the sheet late next week so we can see A/F ratio change & hopefully more power
-Matt
-Matt
If it would help you i can email my hp/ torque graphs with a/f ratios for reference purposes. It has my stage 1 TT numbers which were powerful but the car ran too lean and refused to run without detonation, unless i added a lot of 100 octane gas. It was a real PITA and taught me to be very wary of
all tuning shops.
Good Luck and protect that expensive engine of yours
all tuning shops.
Just wanted to say thanks for your concern on the tuning/engine.
I'll tell ya this, the car seems to be gaining Hp as I drive it. The slightest touch on the throttle & its just GONE
. The exhaust tone on this thing sounds like a NASCAR (at 2,000 RPM its loud, anything higher & it thunders like a race car
).Y'all have a good weekend.
-Matt
Dinko
OK, its Friday, & I'm working too much
. Just playin' Dinko.
. Just playin' Dinko.Dinko
Is it underrated?I'm not trying to start a flame war, I'm just curious. I would expect it to be in the 11's or even high 10's.
). I'm figuring.......a stock C6 w/400 Hp (manual 6 Spd Coupe) has 45 more Hp & weighs less than the SLK55, yet runs the same quarter mile. A C6 Z06 is putting down 40 rwhp (not flywheel) LESS than my initial SLK dyno (450 to 489rwhp). Unless physics are wrong, the S7 SLK is quicker (it should be...the C6 Z06 is stock). In any case, I think a new Z06 will need significantly more power than a modded SLK due to the inhernet advantage of the MB 7 Spd tranny & the fact the SLK engine produces more comparable torque to pull its extra 230lb heft (I had 460 Tq on the 1st pull that netted only 383 rwhp, my 2nd pull yielded the 489 rwhp but Tq was not measured due to an electrical short in the dyno conection cable...I'm guessing its putting down signifcantly more than the 1st 460 Tq number). We'll see, going back on the dyno next week now that the ECU has learned. I could be wrong - its just my opinion.
See ya,
-Matt
Tell me when and where. I'd love to check that thing out. I just broke 1k miles and have started to get on it. I think the stock 55 gets a bit scary. I'm sure I'd sh_t my pants in your car.
See ya,
-Matt
Yours is exceeding that by a good 100 ponies, (As Scotty from Star Trek might say) Cap'tn she's got to much powuur!! she might blow!
Remember the C6 Z06 has 315 wide rear tires so the power will be more accessable. I also believe the c6z06 is around 3150 lbs v's the slk55amg stock weight is 3400, and dont forget the added weight of your new supercharger(probably 50lbs). So the difference is more like 300 lbs.
I think it would be a very close race but would rather be in the AMG...i just love the 7 speed tranny
