SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
What to do before the dyno?
Old May 4, 2006 | 11:59 PM
dsb's Avatar
dsb
'06 slk55
Hey all,
I have a couple questions regarding a dyno. I want to get a baseline as I plan to make some engine mods in the future. But first, questions...
Will AM wheels that are heavier than the OE negatively affect the dyno numbers? Should I mount the OE wheels for the dyno run?
Also, besides putting the car in Dyno mode, are there any other precautions?
Thanks,
Dan
Old May 5, 2006 | 10:57 AM
Yellow R1's Avatar
'93 RX-7, SLK55
Originally Posted by dsb
Hey all,
Thanks,
Dan
Hi Dan.
No noticable impact of using lighter weight rims/tires on a dyno - just does not show up since the car is on a "roll" & the delta in this scenerio is likely within a few Hp. Less unsprung weight DOES provide a benefit, just a not noticable one on a roll/dyno. I know it seems counterintuitive, but that is what I have read on a few forums - like the Vette forum for example.
You should get between 295 - 305 rwhp baseline. Just make sure the car has access to good airflow via a strong fan & its preferabley cool weather (60 - 70s is optimal). A good 4th gear pull works well for the 7G. Post results if you get the chance. See ya!
-Matt
