Engine oil~help
" observe time.........."
Any comments?
regards
BTW, You can measure the exact oil level by doing this:
taken from Bloflin's post...
You have to put your display into "service mode". Search the forums, you will find it, but from memory (may have mistakes).
Turn ignition on (car NOT running).
Have digital display showing the Odometer display.
Hit the Reset button (small black button on the left side of the Speedometer gauge), THREE times in a row.
Digital Display will change to showing Voltage on the battery.
Hit up arrow a couple of times to get to the Oil measurement
****Turn the key to position 2 and wait
After that you can even start the engine and watch the level drop some as the oil is pumped up into the engine.
Be aware there are other functions in this mode (at least one of which will reset your time to service reminder). So be careful. Also how the up/down arrows and the page up/down controls the functions does NOT seem real intuitive (to me).
P.S. After writing this, I'm thinking perhaps you start in ACC mode, then swith to On (still car not started) after getting to the Oil Measurement display. Not sure. Again search the forums.
or should I wait for the next service "if the remaining is only 2,000km for the next service"?
thanks..
thanks..
This way, you'll still have another half a liter left in case your car demands more another 10,000km's from now.
My dealer told me that it's usually best to add just a little less then what it asks, as it is very easy to overfill the 55 engine.
thx so much ..i'm goin to try now.
