Transmission problem
I was driving and came to red stop light. I stopped. When the light turned green I applied gas, but the vehicle wouldn't move. The RPMs went up, but no forward movement. So, with a line of cars behind me I put it in Park and then back to Drive. Still the same problem. Tried Neutral to Drive with the same problem. Tried Reverse and got the same results. Then I put it in Park and turned off the ignition. I sat for a moment and then restarted the vehicle. When I put it in Drive I was able to get home, about .5 a mile away, but it was making a new noise from the rear end.
It is in the shop now, but has anyone else experienced a similiar situation?
Andy
Wife starts the car in the cold morning, puts the car in reverse and then drive, jerking both times and then the car will not shift out of second gear. It acts like the auto stick is engaged and will not allow it to shift.
She has to shut the car off and restart it. After which it runs fine. No clue what is going on.
check this https://mbworld.org/forums/slk55-r171/175102-gearbox-problem-can-i-still-go-kleemann.html
wish you all the best.
I appreciate the response. The car is at the delaership now and I am just waitinng for a response. How long did the repair take? Days ? Weeks? Just curious.
Andy
check this https://mbworld.org/forums/showthread.php?t=175102
Andy
-Matt
Andy
Actually my Audi is acceptably comfortable and my 55 is a 2006 CPO with less than 10K. So, it is under B-2-B warranty. I have asked if there is an upgraded transmission tha can be put in the vehicle without affecting warranty. I should find out the response today.
Andy
If the car has been sitting for a long period of time (overnight), one possibility the fluids have settled and/or viscosity has changed because of the cold weather - I guessing that this may be a cause, so go easy on me my fellow members.
Next time when you start your car, let it run for more than a minute or so. I haven't had the problem since doing this way. See if this works for your SLK.
Thanks Andy
Do you drive your car very hard?
