SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
Stereo overloading?
Old Mar 6, 2007 | 01:34 PM
Catchmefucan's Avatar
Stereo overloading?
When cruising on the freeway at 75 MPH with the top down, I generally have the Harmon Cardin stereo turned all the way up. Usually, I am listening to my Ipod, also turned all the way up, and my stereo will cut out after approximately an hours time. This is really irritating because when the stereo cuts out, so does the navigation and everything else associated with the Command system. What are the alternatives? Do I take it in for warranty? or can I put in a new system to replace the existing? Maybe just a new amp for the stereo? I am not sure how to resolve this issue. The sound on the stereo system is acceptable, but this problem is really irritating.
Any input would be greatly appreciated.
Andy
Old Mar 6, 2007 | 03:44 PM
Scoobysnack's Avatar
mine does this once every 2 months........... I think its something to do with my nokia phone install
J
Old Mar 6, 2007 | 03:58 PM
SLK55R's Avatar
'10 Porsche Turbo PDK, 500e, GL450
problem
Never experienced this problem in over 1 1/2 years. Take it in.
Old Mar 6, 2007 | 05:09 PM
bigswol2's Avatar
2003 E 500
check the positive battery cable
Old Mar 6, 2007 | 05:57 PM
JLP's Avatar
JLP
06 E-55-95-F355S- 99 Porsche 911 C2 w mods
Do you have your heater on as well?
Old Mar 6, 2007 | 10:11 PM
Thanks for the responses. I'll check the battery terminal, but I don't think that is the problem. It only happens when the stereo is all the way up and after about an hour or so. The heater is not on. I thought thast may be it, but I am now driving with the top down in SoCal with the A/C on. I am going to mention it to the MB service rep at my next service.
Any other suggestions?
Thanks.
Andy
Old Mar 8, 2007 | 06:42 PM
bloflin's Avatar
2005 SLK55 AMG
Thanks.
Andy
What MY and build date is your car?
Early early versions of MY 05 had audio gateway overheat issues.
My later build (April 05) had intermitent (but very rare) issues (volume to max by itself once, shutdown twice) over 18 months. Also would get lost with MP3 disks occasionally, or take a very long time to start playing.
At 10K maintenance told them, they checked and updated the COMAND and Audio Gateway software.
Also added "new functions" like, more shuffle play modes for mp3 and now the MUTE buttons not only mutes but also PAUSES the mp3. I assume these functions are in MY07 (maybe even 06), but I sure appreciated them.
Also it never gets a hung/lost mp3 when starting up, anymore, which was my main gripe.
Old Mar 8, 2007 | 07:30 PM
billtc55's Avatar
Porsche Cayenne Turbo
Audio Gateway is overheating. I had the same thing with my SLK55
the third AWG was the magic one, problem gone
Old Mar 9, 2007 | 10:15 AM
Thanks for the info. Something is definately overheating. I'll mention the audio gateway issue to my service rep on the next service. Is there a TSB or is this just a common knowledge issue? My SLK55 is a 2006 built in 07/05.
Thanks again.
Andy
Old Mar 9, 2007 | 11:22 PM
in2dwww's Avatar
I actually think that there's a recall on overheating COMAND units. You should really check with your dealer on that. It sounds to me like it's getting too hot for operation and protecting itself by shutting down.
Old Mar 11, 2007 | 08:49 AM
billtc55's Avatar
there should be overheat codes stored
Old Mar 11, 2007 | 09:04 AM
Shark's Avatar
'05 SLK55, Obsidian, black/red, light and premium pkg., COMAND with nav, airscarf, Sirius
There was a TSB published by MB on this perhaps 18 months ago. You should be able to locate it in the TSB "sticky" at the top of this forum. I have an early '55 and had the same problem. MB acknowledged the problem and said they were working on a fix, and several months later they published the TSB which instructs the dealer to add a cooling fan to the audio gateway. My dealer made the repair to my car and that solved the problem. I'm under the impression that newer '55's came from the factory with the cooling fan already installed. How old is your car?
Old Mar 17, 2007 | 10:25 AM
mbtek69's Avatar
Do you all have the TSB number? Or can you tell me where you found this? I am interested as well.
