2009 SLK & 55 engine
MB / AMG should make the SLK lighter, My car's registration paper's say that it weight's 1,540kg which I think is slightly heavy for such a small car.
P.S. 0-60 means absolutely nothing. One person could get a 0-60 of 5 seconds and another person could get 4.3 seconds on the same SLK55, it all depends on how you launch the car and the available traction. If you put slicks on your SLK55, you could get a 0-60 of 3.8 seconds or less.
0-60 was just a reference of what most people will look at when looking at the specifications. My intention was that the power should be raised and if you can't have the 63 (r171 chassis can't fit the engine and/or xtra fuel pumps) then for the time being an Slk55 400hp would be a good option and easy to do.
What most people fail to realize is that HP does not necessarily translate into 0-60 times. When I had my lotus elise (190hp), I often had no problem taking cars like Z06's and Vipers w/ 500hp+ in 0-60 since they have poor traction at launch, front-engined RWD cars are the worst in that regard. No matter how much power you have, if you're not putting it to the ground, all you're doing is either burning rubber or seeing "ESP" light flashing.
