SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
ECU UPGRADE ETC
Old Aug 15, 2008 | 06:46 PM
gazza1's Avatar
PORSCHE CAYMAN
ECU UPGRADE ETC
Was wondering if anyone can point me in the right direction for some enhancements to the Slk55 amg
Ecu Upgrade/ Lowered Springs along with the 19" Rim size required to run 265/30 rears and the offset number for the rim.
Old Aug 18, 2008 | 09:14 PM
A' La F1's Avatar
2006 SLK 55 amg, 2002 CLK 430 Cab (hers), 1989 944 Turbo (sold), CLK 500 (sold), 125cc shifter kart
I'm using Powerchip Group ecu flash in my SLK 55, but using Speed Innovation ecu flash for my CLK 500. I think the Powerchip Group flash is a bit more aggressive; need to run 92 octane on their "91 Octane" flash. Don't recall the offset on the wheels, but Tirerack can provide that data for you. Springs, I am using Eibach/Brabus. H&Rs are also available, but they are a bit stiffer I am told. Height can be adjusted via the Mercedes pad system.
Old Aug 19, 2008 | 06:32 AM
gazza1's Avatar
PORSCHE CAYMAN
Thanks A'La F1 for the info...I thought I was out there all on my own.
Old Aug 19, 2008 | 01:48 PM
IIIMBPIII's Avatar
07 SLK55, 08 R32
I am getting the Speed Innovations tune on the 30th it was to good of a deal to let pass. Ill tell you how it goes!
Old Aug 19, 2008 | 01:59 PM
A' La F1's Avatar
No problem. There is A LOT of great information on this forum, problem is it is sometimes difficult to find. Great information on lowering, the pad system (pads are numbered 1 thru 4 by Mercedes depending on thickness of the pad), exhaust options (resonator delete, x-pipes, headers, cats, mufflers, etc.), power pulleys, wheels, brakes, ecu upgrades, supercharging, carbon fiber pieces, antenna options, etc.
Tuning high end cars is not only expensive, but sometimes you can go in the wrong direction. If you have questions, feel free to PM me and I can hopefully point you in the right direction.
