slk55 vs e63 anyone?
2013 SL550 2013 M6 f12 2011 X5M
hi guys,
I asked this question in the e211 forum and got not too much response. I'm just curious to know if anyone here ran against a e63 amg and what was the results. Thanks
george
george
1 Post
Lotus Elise SLK55
http://www.caranddriver.com/content/...CD06_SLK55.pdf
http://www.caranddriver.com/content/...comparo_ts.pdf )
2006 SLK 55 amg, 2002 CLK 430 Cab (hers), 1989 944 Turbo (sold), CLK 500 (sold), 125cc shifter kart
Agree. And we spend most if not all of our time between 0 and 85 mph. Don't forget the other 2/3s of the equation; braking and cornering. The tiny SLK will crush the portly E63. Especially if springs and wider wheels/tires are installed.
SLK55, Mustang 480hp, CBR600rr
You're right about 0-60 there won't be much difference, but after that E63 will walk away no problem. From a roll, E63 will take it every time, stock for stock. If you look at 1/4 mile trap speeds, its around 110mph for SLK55 and 115mph for E63.. that's about 5 car lenghts by the end of 1/4 mile and the gap will only grow. 0-150, SLK55 takes about 28 seconds, while E63 takes only 23 seconds, which is a huge difference (according to C&D tests:
Note:
In those 2 links you pasted the e63 only beats the slk55 by .1 sec in 1/4 time that wouldn't be 5 car lengths. Even from a roll the e63 only bests the slk55 by .1 (5-60) so it really doesn't get an advantage there. Maybe at a higher starting speed it might like 20-30mph. Basically the e63 has to hunt the slk55 down in last part of the 1/4 at 70mph+ that is why it has a higher trap speed. After the 1/4 it gets ugly and the e63 just walks away.
I think because of the SLK55s light weight combined with it's current performance #s, AMG is reluctant to up it's hp over 400(just going to DOHC heads would probably bump hp over 400). Let's say AMG bumped SLK55 hp up to 450-475, this would probably make it the fastest(besides the SLR) AMG, since it is so light compared to other models. Granted other much more $$$ models would pull on it over 120mph, but how often are you driving that fast?
Pp
