SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
AutoTalent | Renntech Air Box + Brake + Transmission for Mercedes-benz Slk 55 Amg
Old Oct 31, 2019 | 04:20 PM
AutoTalent's Avatar
SPONSOR
G55
Golan@AutoTalent.com
Renntech Carbon Fiber Flat Top Air Box
Click HERE to order Carbon Fiber Flat Top Air Box!
RennTech Carbon fiber air box for the Mercedes V8 engine (M113/112). RennTech full carbon fiber airbox is more than just an impressive under the hood showpiece. By allowing a greater volume of intake charge air; our carbon airbox upgrade allows for greater horsepower and torque across the entire RPM range. The result is an additional 10 HP and 10 Lb/ft with increased throttle response and improved drivability.
Features
Allowing a greater volume of intake charge air
Long-lasting and driver reliability
Incredible performance gains
Allows for greater horsepower
Increases the performance
Allows for greater torque
Gain 10 HP and 10 Lb/ft
Full carbon fiber airbox
Renntech Steanless Steel Exhaust Headers
Click HERE to order Exhaust Headers!
RennTech stainless steel and ceramic-coated exhaust headers offer true bolt-on installation, mounting directly to the OE down pipes and all RennTech headers are hand built from mandrel-bent, seamless tubing and CNC machined stainless flanges. RennTech stainless steel and ceramic-coated exhaust headers offer true bolt-on installation, mounting directly to the OE down pipes - and all RennTech headers are hand built from mandrel-bent, seamless tubing and CNC machined stainless flanges. Advanced computer aided design (CAD) and flow-analysis software allows RennTech headers to deliver substantial gains across the entire RPM range. RennTech headers are constructed of the highest quality T-304 stainless steel and are ceramic coated to further reduce latent heat in the engine compartment as well as combat against thermal stress. RennTech electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that RennTech proprietary SS Exhaust Headers offers incredible performance gains and rock solid daily driver reliability.
Features
Reduce latent heat in the engine compartment
Stainless steel exhaust headers
Ceramic coated exhaust headers
Gains up to +15 HP & +20 TQ
Renntech R1 Performance Package
Click HERE to order R1 Performance Package!
The RennTech R1 Performance Package is the perfect entry level performance upgrade for the SLK 55 AMG. The R1 performance package, The R1 performance package for the Mercedes 55 series engine includes our proprietary ECU upgrade in addition to our full carbon fiber airbox upgrade which offers a larger volume of incoming air for better engine breathing and improved cylinder filling. The R1 performance package for the Mercedes 55 AMG engines includes proprietary ECU upgrade, in addition of proprietary ram air inlet housings for the inatke system, this combination that provides huge increases in horsepower, torque and throttle response across the vehicles entire powerband while still maintaining daily driver reliability.
Features
Gains up to +30HP & +24TQ
Significant gains in horsepower
Significant gains torque
Increases horsepower
Increases throttle response
Increasing the engine's rev limiter
RennTech ECU Upgrade
RennTech Carbon Fiber Air Box
Stock Performance
355 Hp @ 5750 Rpm; 376 Lb-ft @ 3500 Rpm
Modified Performance
385 HP @ 5500 RPM; 400 LB-FT @ 3000 RPM
Renntech Performance Brake
Click HERE to order Renntech Performance Brake Package 1!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
Deliver more consistent brake pedal feel
Improves vehicles responsiveness
Reduce fade compared to stock
High-performance brake pads
High quality material used
Improved performance
Long-lasting reliability
Braided steel lines
Renntech Performance Transmission Upgrade
Click HERE to order Performance Transmission Upgrade!
RennTech transmission upgrade consists of a complete transmission disassembly and inspection as well as a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings as well as a new transmission pan filter. RennTech 722.9 Five speed Mercedes Transmissions increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. RennTech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Increased engine performance
Improved shift response
Greater drivability
Shift timing
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
Old Dec 12, 2019 | 03:12 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Dec 27, 2019 | 12:46 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
Old Jan 3, 2020 | 02:22 PM
AutoTalent's Avatar
SPONSOR
G55
Bump!
