SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
P0444 error
Old Mar 5, 2020 | 09:06 PM
nicwilson's Avatar
SLK55 AMG
P0444 error
The engine management light came on right after an engine wash. I thought moisture in the EVAP valve wiring. I removed the wiring and dried and cleaned the connector. I reset the error in the ODB2 port. The problem was gone for about 2 weeks when the same error came back. The error states the EVAP is an open circuit. I removed the wiring on the valve and measured it with a Fluke meter, and it read 28 Ohms (from research this is an expected value of a good valve), I compared it with a known working SLK55 without error and it gave the same value of 28 Ohms. I have cleaned the connector and port again and have reset the error.
Does anyone have any other thought on this error or what else I need to check?
cheers
NicW
