SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
Vivid Racing -- VR Tuned SLK55 AMG Flash Tunes, 20% Off!!
Old Nov 14, 2023 | 06:25 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Post Vivid Racing -- VR Tuned SLK55 AMG Flash Tunes, 20% Off!!
Looking to spice up your R171 SLK55 AMG this Fall?!
Vivid Racing has you covered with our in-house favorite -- VR Tuned!
Price: $800 $640 (Code VRTBFCM)
VR Tuned ECU Flash Tune Mercedes SLK55 5.5L V8 AMG R171
Why choose VR Tuned?
The Mercedes-Benz SLK55 5.5 V8 AMG is a load of fun to drive! The VR Tuned Flash Tune upgrade adds more horsepower compared to stock numbers. With our ECU calibration, you are able to gain improved performance on the engine, stock or modified!! The biggest difference when you flash tune your car is the overall gains found across the entirety of the power curve. Your car will have much quicker throttle response no matter what type of transmission you have. Where your car is sluggish off the line, your newly flashed car picks up right away and pulls harder through the mid and top end RPM range. Overall, the driving characteristics are vastly improved while providing you additional benefits that your car desires, less economy car, more performance car!
Check out our blog on tuning if you're new!
Power Ratings!
Stock Power: 360hp | 376ft/lbs
Tuned Power: 397hp | 394ft/lbs
Options!
Vmax Off
- This is an increase or reduction of the maximum speed limit.
Race Exhaust - This option is for those running full race exhaust systems. (Cat-Delete Req.)
Pops & Bangs - Pops and bangs (burble tune) is the result of an ignition delay which creates an exhaust detonation when the throttle pedal is released. Caution, this process must only be used on vehicles with a full race exhaust. This may affect long term engine reliability.
Cold Start Off - Disables the cold start system.
Power on Driving Mode (Sport button) - When you press the Sport button, the tuned map is activated.
DTC OFF - This option is to delete Trouble Code (DTC) related to the engine. You provide us the code.
**Some options are not available for different software version of the vehicle. We cannot know this until the factory ECU read is uploaded. If a feature is not available that is extra, we will refund you that amount. We do guarantee to provide you with the best possible performance tune.**
Questions? Connect with the team!
forums@vividracing.com
(480) 966-3040
Direct Email @
tristans@vividracing.com
Extension 239
We can't wait to hear from you!
Tristan Shallow
Vivid Racing
Performance Specialist
(480) 966-3040
