SLR McLaren (C199) Discussion on the SLR Coupe, Roadster and Sterling Moss Edition.
SLR/C199/R199/Z199: Changing spark plugs on Mercedes SLR Mclaren (Easy Way)
Old Jun 1, 2016 | 02:16 PM
irushaud's Avatar
E 320
Do not take the engine out to change spark plugs on SLR Mclaren.
I've changed spark plugs on many SLR's. Complete job gonna take 8-10 hours max. Steps as follows.
1. Disconnect ground cable from the battery
2. Raise vehicle
3. Remove bottom engine compartment panelling.
4. Remove both side exhaust mufflers.
5. Remove both side charge air coolers (this is the difficult part of the job) To do that-
* First take out all the bolts (8 manifold & 2 mounting bolts- T30, T45
bolts) and disconnect hose clip at back.
* Gently pull the cooler front and remove rear mounting bracket (E10 bolts)
* Gently take coolers out and keep on the wheel arch. (For RHS cooler-
Disconnect and block 2 bleeding hoses connecting to radiator expansion
tank). No need to remove any coolant hoses connecting to cooler. They are flexible and long enough to do the job.
6. Remove ignition coil with plug leads. (You have enough room to do it, no need to remove exhaust manifolds)
7. Replace spake plugs.
Old Oct 8, 2017 | 02:36 PM
nickedwards's Avatar
amg
Old Oct 26, 2017 | 05:35 PM
ecmexchange's Avatar
Former Vendor of MBWorld
na
Thanks for the easy steps
I am definitely liking this approach to replacing my spark plugs. Thanks
