SLS AMG Gullwing (C197, R197) 2010 - 2014
SLS/R197/C197 AMG: Lambda Oxygen Sensor Failure
Old Dec 12, 2011 | 02:59 AM
SLS Qatar's Avatar
2011 SLS AMG, 2009 SL63 AMG, 2008 C63 AMG(SOLD)
Question Lambda Oxygen Sensor Failure
The lambda sensor before (pre-post) on my SLS on the passenger side has failed and is not giving appropriate readings. This happened after installing the new exhaust system. The reason behind it maybe because it was no tightned enough as was said to me or it maybe because of the new location of the sensors since the new headers are very long.
Right now I will replace both lambda sensors and I just ordered them from the dealership.
I am just wondering if in the future the same thing happens, can I buy universal Lambda Sensors? Will they work?
Here are some I found on this website http://www.autopartswarehouse.com/sk...ytic+Converter
Just want to know if it is compatible
Old Jan 22, 2012 | 03:41 PM
Mosdef419's Avatar
ML320
I also had this issue with my ML320, I was aadvised when I did my MOT that my Lamda sensor was playing up and high revs, but on low revs it was fine, reading this post could be b'cos I recently installed a Cat back exhaust but I did not touch or the sensor
Have you rectified this problem, please advise
Cuse
