SLS AMG Gullwing (C197, R197) 2010 - 2014
SLS/R197/C197 AMG: SLS Sway Bar Drop Links
Old Apr 30, 2013 | 02:02 PM
Staff@WORLD's Avatar
Former Vendor of MBWorld
2012 Mercedes SLS, 2014 Mercedes SLS Black Series, 2014 E63S, 2013 S550, 2012 ML63, 2013 C250
Did you install coil-overs on your SLS? Are you looking to corner balance your car and set your car up to handle at its full potential? If so you will need to install a set of RADO sway bar drop links. The drop links are manufactured using the highest quality components and custom machined spacers to prevent binding and rod end damage. These are the same drop links used on Cup style race cars Challenge race cars.
These links give your vehicle the ability to prevent and pre-load from the sway bar after corner balancing your vehicle. We have found that they also work well on all lowered SLS's.
WHOLESALE INQUIRIES WELCOME
Old May 3, 2013 | 12:59 PM
Combine these sway bar end links with this KW suspension for the ultimate upgrade in your suspension.
All of these parts are IN STOCK and can be on the way to you TODAY.
