SLS/R197/C197 AMG: Newbie with 2013 SLS GT- Rear Creak
I am having one small issue with is a creaking from the rear. Its there 100% when going over speed bumps but not smaller bumps. It seems to ba a trim or body issue rather than a suspension related one as it does not happen at the same frequency as shock absorber movements.
It seems to be from beneath the rear shelf or from the trunk lid.
The car does have a space saver lodged in the trunk but that seems pretty secure.
Any one suffered the same issue?
On my 2012 SLS AMG, I would occasionally hear a squeak coming from the rear deck shelf on a bumpy road near my home. Lifting the shelf I found four plastic pins that seat into four plastic holders that secure the deck in place. I believe that the plastic pieces rubbing against each other caused this squeak. Applying a lubricant safe for plastic to the pins apparently has solved the problem for my car. I hope this approach works for you too. Let us know!
MB has agreed to cover the work via goodwill. They will replace the ARB first and see if that solves the issue (I think it will given that the noise is from both sides and it feels 'interconnected') If not then they have agreed to replace the dampers too.
Great service...in fact so great it convinced me to purchase a new (demo) CLS400 as a daily driver.
It was a great deal given that the cars are about to be replaced.
Enjoy your new daily driver!
After this, I just had 2 loud rattles when going over the horrible ceramic (yes ceramic!) lane dividers we have in Abu Dhabi. I am not sure these rattles would appear in any other country.. these dividers are pure punishment for cars in Abu Dhabi. After a lot of trial and error I found the source of the rattles.
1. The interior light console was slightly loose. I carefully prised it out of the housing on the roof (using a door trim removal tool on the side facing/nearest the rear window). There are two tabs that hold the console in place that need pusing back to release the console. I found some foam packing that looks very OEM and fitted it to the void area in the roof of the car and this then stopped any play between the console and the housing/roof liner.
2. The glovebox lid was slighlty loose on one side. I added a small felt insualation on the inside of the glovebox that the lid latches to.
The car feels 90% more solid with all this done. Last piece is to fix a few small rattles and small squeaks from the rear parcel shelf.
