SLS AMG Gullwing (C197, R197) 2010 - 2014
SLS/R197/C197 AMG: Trunk Outlet Converted to a Conventional Charging Outlet and Power Source
Old Jul 21, 2017 | 06:10 PM
subscriber's Avatar
1999 CLK, 2000 S, 2003 SL, 2004 E
Three items are needed.
Cigarette Lighter Receptacle with spade connectors from any auto parts store. Eagle nylon bushings MP13716 and MP10915 available at your local ACE hardware store.
Of course save the existing components!
Procedure (refer to the images):
1. Enlarge the hole in MP13716 with a file so MP10915 will fit inside
2. Cut a slot in MP13716
3. Modify MP10915 as shown on the images. A sheet metal shear works best
4. With a sheet metal shear cut approximately 1/8 to 3/16 in. from the length of the outer ground cylinder
5. Cut off approximately half of the outer cylinder spade connector
6. Assemble as indicated
Attached Thumbnails Trunk Outlet Converted to a Conventional Charging Outlet and Power Source-11.jpg   Trunk Outlet Converted to a Conventional Charging Outlet and Power Source-12.jpg   Trunk Outlet Converted to a Conventional Charging Outlet and Power Source-13.jpg   Trunk Outlet Converted to a Conventional Charging Outlet and Power Source-14.jpg   Trunk Outlet Converted to a Conventional Charging Outlet and Power Source-15.jpg
Trunk Outlet Converted to a Conventional Charging Outlet and Power Source-16.jpg   Trunk Outlet Converted to a Conventional Charging Outlet and Power Source-17.jpg   Trunk Outlet Converted to a Conventional Charging Outlet and Power Source-18.jpg   Trunk Outlet Converted to a Conventional Charging Outlet and Power Source-19.jpg   Trunk Outlet Converted to a Conventional Charging Outlet and Power Source-20.jpg
Trunk Outlet Converted to a Conventional Charging Outlet and Power Source-21.jpg   Trunk Outlet Converted to a Conventional Charging Outlet and Power Source-22.jpg   Trunk Outlet Converted to a Conventional Charging Outlet and Power Source-23.jpg
Old Jul 21, 2017 | 08:08 PM
Sandy Eggo's Avatar
'00 SL600
Or just use the parts the car came with and use the charger as designed. If you don't have them, get your dealer to order them - not terribly expensive.
I'm confused why anyone would want to do this? Interesting work-around but just why?
The magnetic connector is cool and unique. I don't believe any other Mercs have it.
Old Jul 21, 2017 | 10:22 PM
NewportSLS's Avatar
SLS AMG
Second that ... But thanks for the DIY write up.
