SLS/R197/C197 AMG: AutoTalent | Renntech Performance Ecu+turbo+brake for Mercedes-benz SLS Amg 2011-2014
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. The RennTech tuning software for Mercedes offers significant gains in horsepower and torque across the vehicles entire power band. By modifying ignition timing and throttle mapping, optimizing air/ fuel ratios, increasing the engines rev limiter and modifying boost mapping for turbo charged vehicles, RennTech performance software unleashes your Mercedes true potential. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's! Our experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
Features
Gains: 30HP & +14TQ
Long-lasting and driver reliability
Significant gains in horsepower
Increases the performance
Significant gains torque
Increasing the engine's rev limiter
Incredible performance gains
Up to 593HP and 495TQ
Stock Performnce
563 HP @ 6800 RPM; 479 LB-FT @ 4750 RPM
Modified Performance
593 HP @ 6800 RPM; 495 LB-FT @ 4750 RPM
Renntech Aerodynamic Partys
Click HERE to order
Aero Carbon Fiber Front Splitter
Click HERE to order
Aero Carbon Fiber Rear Diffuser
Click HERE to order
Aero Carbon Fiber Side Skirts
Click HERE to order
Aero Carbon Fiber Adjustable Wing With Lip Spoiler
Click HERE to order Carbon Fiber A1 Aero Package
Click HERE to order
Carbon Fiber A2 Aero Package
RennTech carbon fiber front splitter integrates flawlessly with the original lines of the vehicle while boosting the overall testosterone level of the sporty SLS. RennTech one piece front splitter flows seamlessly into the front apron and is a simple, bolt on component which improves vehicle aesthetics and increases front end down force. All this while still maintaining the same approach angle as the OE front fascia so the RennTech splitter retains the same clearance for parking stops and steep driveways. This piece was designed and engineered in house by RennTech and is a fully functional component which functions in complete harmony with our complementary rear diffuser.
Side Rocker Panels:
These proprietary carbon fiber side skirts were designed to complement the RennTech front splitter and rear diffuser. This side skirt kit includes 4 high quality pre-preg carbon fiber pieces; 2 rocker panel extensions and 2 rear fascia trim pieces. These exceptionally unique and refined aerodynamic pieces complete the RENNtech SLS aero package by integrating flawlessly with the original lines of the vehicle while boosting the overall testosterone level of the sporty SLS.
RennTech side skirts feature an OEM level of quality; in addition to perfect fitment to the factory rocker panels and lower rear fascia. Furthermore, these components utilize factory mounting locations within the rocker panels and a few additional hard attachments are required underneath the rear fascia. Finishing of the carbon fiber parts comes in the form of a high gloss UV protectant coating. Matte finish is also available per special request and may require additional lead time.These parts were designed and engineered in house by RENNtech and are fully functional components that feature unmistakably unique styling for the SLS AMG.
Diffuser:
RennTech rear diffuser is the companion component to the front splitter and functions to decrease drag and increase down force by improving the underbody airflow and its transition to ambient air. As with the front splitter, our rear diffuser is manufactured using the high quality prepreg carbon fiber and is a quick and easy install that requires no modifications to the SLS’s rear bumper or underbody.
Adjustable DTM Wing:
The adjustable wing is comprised of a decklid lip spoiler that sits just aft of the factory retractable wing, which is now static. The lip spoiler features two highly integral stanchions which serve as both the connection to the upper wing element and the location of adjustable carbon fiber struts. Greatly improved downforce is provided predominantly by the centerpiece, wing element. The center section of the wing gradually pulls rearward and sharply terminates to further increase functionality. The latest in aerodynamic developments inspired extractor elements which are unmistakably unique styling features integrated within the 100% carbon fiber end plates. These extractors reduce drag by pulling air flow from the top surface of the wing, out through the sides of the end plates.
Features
Provided predominantly by the centerpiece, wing elemen
The latest in CAD surfacing technology
A quickly and easy install
Gloss and Matte Finish
Fully adjusting wing
rapid prototyping
Perfect fitment
Renntech Ss Valved Sport Exhaust System
Click HERE to order Sport Exhaust System!
Back pressure monitored exhaust system with two exhaust valves for the Mercedes SLS AMG. Made of 1.4828 (T309) stainless steel. Now with German TUV approval. The muffler is back pressure-controlled and freely programmable. There is a control unit for monitoring the back pressure. A built in limit prevents reaching dangerous pressure levels. This control unit provides the ability to individually program the back pressure one would like to have the valves open or close. The portion of back pressure resulting in a loss of performance is filtered out. This way, one can reach the maximum performance. Therefore, this sports exhaust combines all advantages in both the lower and higher range of revolutions (rpm), since the back pressure can be exactly controlled to enable the engine to gain the maximum performance. The programmable control unit features an illuminated display showing all functions in plain text in 3 different languages (German, English and Italian) and provides 3 basic modes to be operated via a remote control, namely. In both the cruise mode and sport mode, one can individually program when the exhaust gas valves shall open. One big advantage is that the control unit recognizes the driver’s operation characteristics. If the driver accelerates aggressively, this is identified by our device by the kind of back pressure that is generated, and the exhaust gas valves open immediately. Usual acceleration results in a later opening of the exhaust gas valves.
Features
Provides the ability to individually program the back pressure
Cruise mode - the exhaust gas valves open later
Sports mode - the exhaust gas valves open earlier
Open mode - the exhaust gas valves remain open
A programmable remote to operate the valves
Programmable Remote Control
A twin sound valved muffler set
A secondary cat-delete pipe
Mounting and fitting hardware
Renntech Performance Brake Package
Click HERE to order Brake Package!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
Deliver more consistent brake pedal feel
Improves vehicles responsiveness
Reduce fade compared to stock
High-performance brake pads
High quality material used
Improved performance
Long-lasting reliability
Braided steel lines
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
