SLS AMG Gullwing (C197, R197) 2010 - 2014
SLS/R197/C197 AMG: Re: Thread of these bolts/stud on the underside that hold the lower sill bodywork on.
Old May 4, 2021 | 10:55 AM
ADAMSLSAMG's Avatar
2012 SLS AMG
Anyone know the thread pitch? I need to get some nylock nuts for these. They are on the underside of the door sills to hold the plastic bodywork on. Also..anyone know how to get access to these studs that protrude? Anyone have a shop manula showing where the stud access is? Do you have to take apart the whole door sill?
Old May 6, 2021 | 10:08 PM
NewportSLS's Avatar
SLS AMG
Probably can’t help but... I took them off to install carbon fiber “side pods” I took this pictures so I would always have part number
Old May 8, 2021 | 08:52 AM
litumup411's Avatar
2021 AMG GT BS 2008 CLK63 BS 2011 AMG SLS
It looks like there's a square indentation in the bolt. If you put a wrench over the nut, you may be able to turn the bolt from the bottom using a square drive bit. Once it grabs, tighten with a socket.
