SLS AMG Gullwing (C197, R197) 2010 - 2014
SLS/R197/C197 AMG: No one has taken a 6.2L SLS to 9000+ rpm?
Old Oct 30, 2025 | 01:59 PM
djr48312's Avatar
2009 c63
Hi All,
There are companies that will regrind cams to different lifts and durations... You can get your SLS 6.2L heads ported. You can do some stroking and boring via offset ground cranks and sleeves, you can raise compression via custom pistons.
There is NO ONE that has taken a SLS to 9000+ RPM? With the DOHC, it should be possible to make a 10-12k build ( it's beeen done on pushrods ).
Please advise.
