Not sure which forum I need to be in - 2017 SLC-300 Roadster. The forum titles don't seem to line up with the sub-forum headings. Any suggestions?
Quote:
Part of the issue is that MB has so many models, generations, and chassis numbers, along with cross-over and changing the nameplates.Originally Posted by thehalls10
I don't think we have a specific area for your SLC-300 but we do have some owners and they have used other areas. My suggest is to post in the most relevant area. Is there a section that closes matches?
We are in the early process of reviewing the sections to make it easier to post, which may include some consolidating to make it more clear.
Yes, thanks. I was just pointing out that these were the forum options (and their headings):
SL/SLC-Class (R107)
sub heading once you're in the forum - '71-'89 250SL, 280 SL, 380 SLC, 450 SL, 380 SL, 560SL. (Implies that the SL300 might be included?)
SLK-Class (R172)
sub heading once you're in the forum - '2011-present SLK 200, SLK 250, SLK 55. (doesn't mention the SLC300 at all, but it's the correct platform R172)
SL/SLC-Class (R107)
SLK-Class (R172)
