FS: Camber kit for lowering car
If you Mercedes is lowered by changing new coil spring such as Eibah or H&R , you must need this camber adjusting arm
For almost Mercedes models at rear wheels left and right to adjust the camber angle to be -1.5 as specification to become good grip good handling for both rear tire and keep you rear tires long lasting by wearing at tire inside cornel
DIRECTION: lift up your car the replace the old arm with this camber adjusting arm then lock the bolt and go to alignment the camber to be -1.5 degree (as R129 spec.) for both rear wheels
More details:
info@dostrix.com
More details:
info@dostrix.com
