C63/C300/C350 (W204) Strut Tower Brace - By SMERC Engineering
Old Oct 2, 2009 | 04:48 PM
SMERC Engineering's Avatar
Former Vendor of MBWorld
SMERC Engineering's proud to announce our W204 C-Class Strut Tower Brace.
Applications:
C63, C300, C350 (2008+) *includes all 4matics
Features:
- CNC'd T-6061 Aluminum Brace (high strength, light weight)
- 3/16" A36 Plate Mounts
- Flat Black Anodization Protection on Brace
- Flat Black Powdercoated Mounts (with fine texture) for durability
- Easy Bolt-on Installation with easy removal for access to intake airbox
Smerc Engineering's Strut Tower Brace is designed to connect the front suspension towers together for better handling. During cornering, the Strut Brace will distribute the vertical suspension load between each tower, thus reducing strut tower flex & chassis flex.
Our product features the use of premium grade T-6061 Aluminum, which is known for its high strength, yet light weight properties. The aluminum first goes through a CNC machining process for precision engineering and consistent product output. Although Aluminum naturally resists corrosion better then various metals, to fully ensure corrosion resistance the strut tower brace is put through an anodization process. The anodization will also help protect the aluminum for wear.
The brace is designed for a quick and easy bolt-on installation. There is absolutely no drilling or cutting necessary. A quick 5 to 10min installation by using our detailed instructions. Our design allows for easy access to the intake airboxes.
Price: $329.99
Please feel free to PM us to order, or visit our website http://www.SmercEngineering.com
Best Regards,
Yuta @ SMERC Engineering
yuta@smercengineering.com[/EMAIL"]yuta@smercengineering.com"]yuta@smercengineering.com[/EMAIL]
