FS: W211 E & W219 CLS Evosport Rear 2-piece rotors
1 Post
2007 E63, 2005 Dodge Ram Hemi
Here are the 2 piece Evosport rear rotors for the W211 and W219 AMG vehicles. They are lightly used, about 4,000 miles, and most of it was the drive to and from VA to TX. I put brand new pads on when I put these on so they have worn completely even which is only about .5mm. I sold the car and put a new set of 1-pieces back on and pulled these. You can see a very small circumferential groove on the rear of one rotor. I would love to know how that happened, but there it is. I think maybe $400 plus shipping. They're not heavy so ground should be around $25-30 I'd imagine. Unfortunately they are barely too big for the USPS flat rate priority boxes Pm me or email at ryan.phelps@att.net Thanks.!!
Here's the Evosport text:
For the W211 E55 and E63 AMG as well as the W219 CLS55 and CLS63 AMG that come with factory 2-piece front rotors or have upgraded to the Evosport 2-piece rotors, Evosport offers their 2-piece drilled/slotted brake discs for the rear. The stock rear rotors are heavy 1-piece discs (20.5 pounds each!). Now Evosport offers a solution to convert your rear discs to lightweight 2-piece drilled/slotted dics like the car should have come from the factory. The new rotors are only 13.5 pounds!
Drilled and slotted to match the 2-piece front rotors, hats are lightweight aluminum and hard anodized. And unlike the stock rotors that only vent correct on one side, the Evosport rotors have a Right and Left application for proper venting of the disc.
Designed as a direct brake disc replacement for the OE REAR brake discs (No modifications are necessary. The disc will bolt directly to the car and work with OE AMG brake calipers). Not only will the upgraded multi-piece "floating" discs help mitigate brake fade, but are lighter than stock and reduce unsprung weight by a total of 14-lbs.! This means better acceleration, braking and cornering. In addition, you get to maintain the AMG calipers without going to a more expensive solution that requires replacing them. Also available in SLOTTED design.
looks like a tiny rock got caught in between pad and rotor.
good deal on these though.i would have loved to see this last month,but i bought a set of the Benz Works rotors and had them installed just last week.
1 Post
Are those 2-piece..? Yeah, I would guess somewhere in TN while it was snowing a granule of whatever they were laying down got caught for a little bit...
