Castrol Brake Fluid and BG Stop Squeal
BG Stop Squeal
"Most brake noise is caused by vibrations that occur when pressure is applied. BG Stop Squeal works on the simple principle of impregnating the brake pad with ingredients that reduce sticking between the pad and rotor. When pressure is applied, the vibrations are significantly reduced, thus brake noise is stopped or is markedly less noticeable."
