4 piston rear AMG calipers for sale cheap.
Old Oct 24, 2012 | 08:47 PM
VIPclk320's Avatar
CLK W208
I am selling a set of rear calipers from a Cl600/CL55/S55/S600/SL55/SL600 and i also belive E55/E63. I bought them from a member here a few months ago and never installed them. they are in great condition and the pistons and seals are strong and very good. They also have the brake lines. I am asking for $400 as i'm looking to move them fast. They are silver with mercedes benz writting on them, on the 600 models the calipers come with mercedes benz writting and on the 55s and 63s they come with AMG writting. they are indentical and same part numbers.
Old Oct 25, 2012 | 09:00 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
What are the part numbers? Do you have pictures? Are they in full working order?
Old Oct 26, 2012 | 12:52 AM
VIPclk320's Avatar
CLK W208
i dont have the part numbers but i'm sure it wont fit the W203 C class, you can have brackets made to make them fit but not a direct fit.
Old Oct 26, 2012 | 01:54 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Look at the part numbers printed on the inside of them.... 4 piston CL55 calipers can be made to fit on w203s and w203 pretty easily.
Old Oct 27, 2012 | 01:33 AM
VIPclk320's Avatar
CLK W208
here is some pictures. the number that i found on there is 20.8492.002 2A
They are off of a CL600. it is identical as caliper as the cl55 ecept on the cl600s they had the Mercedes writing instead of AMG. you will also receive the pads and the lines.
Attached Thumbnails 4 piston rear AMG calipers for sale cheap.-caliper-1.jpg   4 piston rear AMG calipers for sale cheap.-cakiper-2.jpg   4 piston rear AMG calipers for sale cheap.-caliper-3.jpg   4 piston rear AMG calipers for sale cheap.-caliper-4.jpg
Old Oct 27, 2012 | 09:27 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Doh! If these were off a cl55, id make ya an offer. The part number is different from what im looking for. GLWS
Old Oct 28, 2012 | 01:57 AM
VIPclk320's Avatar
CLK W208
CL55 and CL600 have the identical calipers, the only difference is that the calipers on the 600 say Mercedes Benz and the calipers on the 55 say AMG and that's the reason why try have a different part number because the dealer needs to be able to order them with the proper logos depending on the application. They are the identical calipers and they are both 90mm from the center of the mounting hole to the other mounting hole center. As far as the offer goes I'm firm on the price.
Old Nov 1, 2012 | 06:09 PM
Craftysince86's Avatar
W211
these are direct bolt onto 211's?
Old Nov 2, 2012 | 02:43 AM
VIPclk320's Avatar
CLK W208
I believe they are a bolt on for the w211 because as far as my knowledge goes the CL, SL, S, E and CLS all have the same 8 pot front 4 pot rear calipers.
Old Nov 2, 2012 | 11:37 AM
megacrazy's Avatar
CLK55 W209, CL63 W216
Hmmm would these work on a 2004 clk55?
Old Nov 2, 2012 | 09:54 PM
VIPclk320's Avatar
CLK W208
You have to get brackets made.
Old Nov 3, 2012 | 02:02 PM
rcompart's Avatar
2005 C32 4Matic - That's Not A Typo! :D
Just an FYI, they are not all the same, S and CL are the same but SL, E and CLS are different.
Old Nov 3, 2012 | 07:12 PM
VIPclk320's Avatar
CLK W208
thanks for the clarification. Are you 100% sure about that? if so that would be great info.
tru... CL600 and CL55 are identical.
Old Nov 18, 2012 | 04:30 PM
malahhaor's Avatar
06 Carrera4
Anyone knows if these bolt on to w221? I'm trying to figure it out but the only info I have is that European w221 s600 is the only upgrade for the rears.
Old Nov 18, 2012 | 04:44 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
no they won't
Old Nov 18, 2012 | 05:13 PM
malahhaor's Avatar
06 Carrera4
Too bad, thank you for info
Old Nov 19, 2012 | 09:44 PM
Mr. JLT's Avatar
To many to list
Pm sent
Old Dec 2, 2012 | 01:27 AM
VIPclk320's Avatar
CLK W208
Still available.
Old Dec 2, 2012 | 11:18 PM
Louie D's Avatar
2015 E400 CAB, 2010 Jeep Compass, 2009 E350 Sedan
I take it they will fit a CLK W209 ?
Old Dec 4, 2012 | 01:19 PM
VIPclk320's Avatar
CLK W208
Hey can fit any car as long as there are brackets made but as far as being a direct bolt on I'm not sure if they will be for the w209 or not.
