FS: H&R front coilover springs $200 W203/W209 incl AMG
Old Sep 5, 2013 | 09:39 AM
greekspec2's Avatar
2005 C55
for you KW owners I have a set of H&R front coilover springs that where powder coated KW yellow asking $200 shipped
springs are 40mm shorter 245mm than KW's 285mm which allows you to have the front perch higher on the strut and have a lower drop without having to use spacers on stock or most wheel setups
here's the link with pics....
https://mbworld.org/forums/clk55-amg...ngs-200-a.html
Old Sep 12, 2013 | 06:27 AM
Blackbradpitt's Avatar
2002 C320
pm sent
Old Sep 19, 2013 | 09:52 PM
greekspec2's Avatar
2005 C55
bump
Old Oct 23, 2013 | 02:58 PM
greekspec2's Avatar
2005 C55
here are the full H&R front spring specs...
free length 145mm
full block height 84mm
loaded height 135mm
avail spring travel 61mm
spring rates....
working rate 286lbs
fully blocked 373lbs
static load 212lbs
