NEW Caliper Brackets for Black Series Brake Rotors On Stock Calipers
Subscribe
Jun 3, 2018 | 04:17 PM
Step up to larger 390mm brakes on the C63 W204
THESE BRACKETS WORKS DIRECTLY WITH YOUR STOCK C63 FRONT CALIPERS (NO NEED TO CHANGE CALIPERS)
Simply install these brackets to your existing stock front calipers - they will push out the calipers to accommodate the larger 390mm rotor (which you will need to purchase separately).
For your consideration:
1 pair of Like New RacingBrake (Racing Brake) Front Brake Caliper Brackets to accommodate the larger 390mm Black Series front rotor.
Includes New Hardware (4 Bolts and 4 Washers) to attach these Brackets to your Stock C63 Front Calipers.
These RB Brackets will work with OEM BS 390mm Rotors, as well as the Racing Brake 390mm Rotors.
They have been mounted to verify fitment:
Will fit the OEM AMG 19" wheels and most 19" Aftermarket wheels.
Will NOT fit the OEM 507 19" Wheels due to a taper in the 507 wheel barrel.
Multiple individuals are successfully running and tracking with these same brackets.
These brackets are NOT sold separately by RacingBrake.
Asking an even $500 with free shipping to Continental US.
Jun 6, 2018 | 05:49 PM
Hump Day Bump
Jun 6, 2018 | 08:20 PM
Are the brackets aluminum or steel? (simple way to tell is if they hold a magnet or not)
Jun 6, 2018 | 08:32 PM
Solid T6 Aluminum Alloy
Jun 9, 2018 | 04:42 PM
The Weeknd BUMP
Subscribe
Currently Active Users (1)
