W221 S350 Yaw Rate Sensor Location
Old Apr 22, 2016 | 09:25 PM
SVKHID's Avatar
w221
Smile W221 S350 Yaw Rate Sensor Location
Hi i got a w221 S350 which i recently replace ABS control unit but is unable to do the road test because the yaw rate sensor was fault. i hv been struggling to find out where does the yaw rate sensor located.its not same as the previous model which located under the driver seat.
please help
thank you
Old Apr 22, 2016 | 09:30 PM
SVKHID's Avatar
w221
this is the yaw rate sensor
Old Dec 16, 2020 | 11:24 AM
Papushkian's Avatar
2009 S450, 2011 GL450, 2008 C300 Sport
Hi, I know this post is over 4 years old, but I have a B48/2 code which is the passenger side frontal acceleration sensor or yaw rate sensor. My part number is the same as yours and I have a 2009 S450, so I assume my sensor must be located in the same location as yours. Were you able to figure out where yours was located? Thanks
