Hi, i got a 2003 c30 amg , after the winter rest i got a problem with the tale lights.
on the left tale side i got only possition light and no brake light . On right tale side only brake light . No turn signals . i have changed the lamps and still no change, checked all fuses i can find and if i take direct plus tn the lampholder everything works .
anyone have some good ide what to do or check?
There is a recall on the tail lights I believe. Free fixOriginally Posted by Henric
Hi, i got a 2003 c30 amg , after the winter rest i got a problem with the tale lights.on the left tale side i got only possition light and no brake light . On right tale side only brake light . No turn signals . i have changed the lamps and still no change, checked all fuses i can find and if i take direct plus tn the lampholder everything works .
Currently Active Users (1)
