722.6 Trans Issues P2500, P2502, P2503, P2222
Old Dec 8, 2024 | 07:11 PM
MB_Alaska's Avatar
2001 ML55 AMG, 2003 CLK500, 2003 C320 4matic, brabus monoblock IV 18”
I currently own a 2003 CLK500 coupe (purchased for the beautiful blue interior) that I’ve owned for about 2 years, but haven’t driven much. Few thousand miles, as I currently daily my lifted ML55. The car drove great upon purchasing… for a while, until it recently started having trans issues.
important note, the car currently has 74k TRUE MILES
trans codes
P2500: transmission has impermissible transmission ratio
P2502: The gear is implausible or the transmission is slipping.
P2503: gear comparison is negative or target gear not reached
P2222: signal of component Y3/6b1( Transmission oil temperature sensor) and(or) Y3/6s1( Starter lockout contact) is implausible
I’ve owned plenty 722.6 cars, and have found them to be relatively bulletproof, with most issues being derivative of electronic part failures. So I assumed the same for this case.
Symptoms began with slow/jerky shifts. Assumed it was the trans plug, got that replaced. Drove fine for a while, problem persists. Eventually, the car began getting stuck in 1st gear. Turning the car off and on always fixed this, though once it started doing this, it began doing it frequently. Again at the same time, it progressed by beginning to slip gear and free rev anytime you put your foot on the gas, typically in 2-3rd gear shift.
When the car free revs, it seems to be partially in gear, as it will allow you to (very slowly) accelerate at very low RPM, like +1 mph ever 2 seconds. But try to give it any more than 1900-2k rpm and boom, slip and free rev. 1-2nd still has noticeable lag, but don’t seem to slip.
Got a trans service, only code shown was P2500. Got fluid, filter, gasket, etc. Old ATF was very dark brown-red, with some aluminum shavings.
Weird thing is, the valve body was quite rusty… car does not seem like a flood car, possibly radiator fluid contamination??? (Waiting on the photos) Also, based on threads concerning this contamination by a faulty radiator seems like it happened fairly early on in these vehicles lives, and were typically addressed early.
I have also checked the TCM in the footwell for the heck of it. Had an oily smell/residue, but didn’t seem to be anything of concern, visually it looks clean/not oily.
Does this seem like the time for a replacement trans (after the radiator is checked and replaced if bad)? I truly did not expect to have serious mechanical issues with a 722.6 on a 74k mile car.
