1991 560 SEL blower fuses
Old Sep 7, 2006 | 12:31 AM
AgieDC's Avatar
I am researching my options for the fan blower on the 1991 560 SEL which recently quite blowing. I believe the freon is fine as the compressor works well and tests full of freon. However, I am unable to verify the fuses for the fan blower. I have read posts discussing the in-line fuse, however I am unable to download any pics and just can not seem to locate this fuse on the firewall. Secondly, if I am to inspect the blower, is it under the right passenger dash? Is there an easier way to jump a connector to test blower function? Thank you for any comments, and I did check the "ignition key backed off slightly" which seemed to have no benefit to starting the blower. Thank you. Chris
