Ic...
99' SLK 230 & 01' CLK 430
Ic...
This picture show that Renntech should weld a bracket here so the customer can mount the IC to the bottom of the bumper support by just un-screw a nut and tight it back.
This picture show that Renntech should weld another bracket here so the customer just un-bolt the side bracket screw and tight it back and the job is done without any kind of drilling to the car frame. And now you have two bracketon each side of the IC just like the factory. Btw, notices that both pictures show the other “adapter” inlet with dimple/bump all around it and so there’s no way you can use the clamp that came with the kit and still get a good air seal/tight. That’s why I only clamped the rubber hose on the edge of the adapter only.
