W639 109cdi won't start/Crank after sam-f change
And also sam gives fault code that i dont remember now, but something like it's defect and should be replaced. But the indicators work now, hooray.hooray.
Is there a bad luck and used sam is broken? Same hw/sw numbers than old one. Or is ecm now broken?
And also I found "Synchronization of control modules N73(EZS) control unit and N3\9(CDI control unit) is being performed --- status NO"
-B102c-002 unknown fault type 2
-B102d-009 signal terminal 15 at Sam does not match with signal terminal 15 at canbus
-B1037-001 component n10 (Sam) has activated emergency lightning, signal from s1(exterior lamp switch) is implausible
