::ECS Tuning:: Valve Cover Gasket Kit For Your CLK-Class With M113 V8
Former Vendor of MBWorld
2012 SLS AMG
![](http://www.ecstuning.com/sales/ecs600header.jpg)
Click HERE to order or for more information.
Kits Starting At - $69.14*
If you're beginning to notice oil drips on the ground, a burning oil smell or smoke from underneath the hood, a leaking valve cover gasket may be the culprit.
A common gasket to leak on Mercedes engines, the valve cover gasket is nothing to ignore, and will only get worse over time.
If the valve cover gaskets are leaking on your Mercedes-Benz M113, we have the solution with this Valve Cover Gasket Kit. This kit includes everything you need to replace both the left and right valve cover gaskets on your M113 V8.
This kit includes the following items:
One (1) Left Valve Cover Gasket
One (1) Right Valve Cover Gasket
One (1) 50ml tube of Genuine MB Sealant
Three (3) Crankcase Breather Hoses
![](http://www.ecstuning.com/marketing/Mercedes_Benz_W209_CLK_Class_Valve_Cover_Gasket_Set/Mercedes_Benz_W209_CLK_Class_Valve_Cover_Gasket_Set.jpg)
*Price subject to change.
