Arnott Update on Aftermarket Air Suspension for Mercedes-Benz Owners
Former Vendor of MBWorld
Mercedes-Benz® Product Update
In recent months, Arnott Air Suspension Products has released aftermarket air suspension parts for Mercedes-Benz at a record pace. To keep you up to speed on these important advancements, here’s an update:
Arnott Air Suspension Products announced the introduction of completely new Front and Rear Air Shocks for the 1999-2006 W220 Chassis Mercedes-Benz S-Class sedan. Arnott's Mercedes suspension design features a custom-made and tuned monotube shock absorber paired with a new rubber air spring bladder manufactured by Goodyear. The bladder is protected by an aluminum sleeve. The Arnott aftermarket design eliminates many of the common high wear points such as the upper epoxy sealing cap, noisy upper mounts, and the weak lower rubber sealing ring.
These remanufactured air shocks apply to OEM Part Numbers A2203202438, A2203205113 (front), and A2203205013 (rear). The air shocks retail for $579.52 each, and are available from Arnott as part number AS-2605 (front) and AS-2606 (rear). A $75 core return rebate applies to each part, making the net price after rebate just $504.52.
Arnott Air Suspension Products announced the introduction of a remanufactured Right Rear Air Strut and a Left Rear Air Strut for the 2007 to 2013 Mercedes-Benz® S-Class (W221 Chassis with AIRMATIC® and without 4MATIC®) and CL-Class (W216 Chassis with AIRMATIC and with 4MATIC). These remanufactured air struts apply to OEM numbers A2213205613 (right) and A2213205513 (left).
The air struts retail for $525.50 each, and are available from Arnott as part number AS-2603 (right) and AS-2604 (left). A $200 core charge applies to each part. Arnott's remanufactured air struts feature a new air spring manufactured by Goodyear.
Arnott Air Suspension Products announced the introduction of remanufactured Front Air Shocks for the 2007 to 2012 Mercedes-Benz S-Class (W221 Chassis with AIRMATIC® and with 4MATIC®) and CL-Class (W216 Chassis with AIRMATIC). These remanufactured air shocks apply to OEM Part Numbers A2213200538, A2213209813, A2213207413, A2213200038 (right) and A2213200438, A2213205113, A2213209713, A2213207313, A2213209913 (left).
The parts are in stock and available for immediate shipping. The air shocks retail for $525.50 each, and are available from Arnott as part number AS-2547 (right) and AS-2548(left). A $200 core charge applies to each part. Arnott's remanufactured air shocks feature new air springs manufactured by Goodyear.
Arnott's new Mercedes-Benz® E-Class Wagon coil spring conversion kit was exclusively designed for the E-Class Wagon with rear air suspension only (without ADS). This kit converts the rear air springs of the vehicle to a reliable coil spring suspension system. Arnott's springs are designed to provide a smooth ride, comparable to the original air suspension.
These aftermarket springs fit perfectly in the seat without welding or modifying the original suspension. The Mercedes-Benz E-Class suspension conversion kit features powder-coated coil springs made from American steel along with top and bottom mounts. The included Installation Manual details how to turn off dashboard air suspension warning lights. Arnott's part number is C-2675 and it retails for just $299.
Arnott® Introduces New AMK Air Suspension Compressor
for 2006 to 2013 Mercedes-Benz® R-Class
Arnott's air suspension compressor for the 2006 to 2013 Mercedes-Benz® R-Class (W251 Chassis) Rear Only Air Suspension is a 100% direct replacement for the original OE air compressor from Mercedes-Benz.
The compressor is new and produced by AMK, the same manufacturer as the original compressor. The compressor is Arnott part number P-2618 and retails for $522.50. The OE part numbers are 2513201204, 2513202004, and 2513202604.
Arnott Air Suspension Products recently tested and released its WABCO Air Suspension Compressor/Dryer for the 2002 to 2013 Maybach 57S and 62S. This popular compressor also fits other vehicles manufactured by Mercedes-Benz, including the:
-- 1999 to 2006 Mercedes-Benz S-Class,
-- 2002 to 2009 Mercedes-Benz E-Class, and the
-- 2005 to 2011 Mercedes-Benz CLS-Class.
The Compressor/Dryer Assembly -- OEM numbers A2113200304 and A2203200104 -- is in stock and available for immediate shipping. The Compressor/Dryer retails for $394.60, and is available from Arnott as part number P-2192. The compressor, a genuine OE unit manufactured in Germany and tested by Arnott in the United States, comes completely assembled with mounting brackets and air lines and is ready to bolt in.
For more information or to order from Arnott's secure Web Store, go to www.arnottinc.com or call toll-free at 1-800-251-8993. A Discount Code is in force for MBWorld members: MBSAVE10. The Discount Code, limited to $75 off the purchase price, not including tax or shipping, does not include Air Suspension Compressors.
Arnott® Introduces New Front and Rear Air Shocks
for 1999 to 2006 W220 Chassis Mercedes-Benz® S-Class
Arnott® Introduces Remanufactured Rear Air Struts
for 2007 to 2013 Mercedes-Benz® S- and CL-Class
Arnott® Introduces Remanufactured Front Air Shocks
for 2007 to 2012 Mercedes-Benz S- and CL-Class
Arnott® Introduces Coil Spring Conversion Kit
for 2003 to 2009 Mercedes-Benz® E-Class Wagon without ADS
Arnott® Introduces New WABCO Air Suspension Compressor/Dryer Assembly
for Three Mercedes-Benz® Applications and 2002-2013 Maybach 57S & 62S
