::ECS Tuning:: W215 CL-Class With 722.6xx Automatic Transmission Service Kit
Click HERE to order or for more information.
Kits Starting At – $91.55*
The Mercedes 722.6xx transmission is a collection of parts that must each be functionally sound for the gearbox to do its job.
It follows then, logically, that when attending to a particular transmission issue, the strength of the weakest part determines the end quality of the system.
For this reason, ECS offers several complete Transmission Service Kits for your W215 Mercedes.
Choose from premium ECS-assembled and genuine OEM packages - each including Automatic Transmission Fluid, Filter, Oil Pan Drain Plug and Sealing Washer, Dipstick Tube Cap Lock Pin, and Pan Gasket.
Furthermore, the transmission fluid in these kits meets MB Spec 236.14, so you can be sure that you are using the correct fluid for your 722.6xx automatic.
*Price subject to change.
