Vendor Announcements New Products, Test Results, Company News etc.
:: ECS Tuning :: New Schwaben Specialty Tools!
Old Jan 27, 2015 | 03:13 PM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
Click HERE to order or for more information.
It's the new year, it's time for some new tools.
Every one of these Schwaben tools are built to last and are easy to use. The Thread Chaser Set includes the most popular metric sizes so you can restore corroded, damaged or stripped threads.The Metric Bubble Flaring kit is a must have for anyone replacing steel brake lines.
The Memory Saver Kit allows you to connect a separate power source (9 volt household battery, or separate 12 volt battery) up to your OBDII port under the dashboard when replacing a battery, preserving radio presets and settings, and other vehicle memory.
*Price subject to change.
Old Feb 3, 2015 | 05:11 PM
ECSTuning's Avatar
2012 SLS AMG
Schwaben Specialty Tools is known for releasing clever, highly useful automotive tools that make owning a European car less frustrating and more fun.
Two new exciting product releases - the Mechanic's Stethoscope and the Scraper, Pick and Hook set - are superb examples of Schwaben reliability and ingenuity.
Featuring an aluminum probe & rubber trumpet, the Schwaben Stethoscope makes finding vacuum leaks, pressure flow noises, and knocks infinitely more simple.
The Scraper, Hook And Pick Set is an indispensable kit with endless uses, from carbon cleaning to picking out o-rings.
Old Feb 10, 2015 | 01:06 PM
ECSTuning's Avatar
2012 SLS AMG
Schwaben Specialty Tools has released three new products that eliminate the pains and inconveniences associated with automotive repairs and installations.
Get off the ground and move around with the Six Wheel Creeper - ruggedly designed to reliably keep your body off the ground while working underneath your Euro.
The Schwaben LED Under Hood Shop Light features 120 LEDs & a polycarbonate transparent lens that instantly illuminates every crevice of your engine bay.
The Rolling Creeper Seat and Tray keeps your body at an ideal height while keeping your tools close at hand.
Old Feb 19, 2015 | 02:58 PM
ECSTuning's Avatar
2012 SLS AMG
We've all found ourselves using highly "creative" methods for separating old parts in the midst of an intense project. Some methods do work - usually at the expense of personal injury and a few broken or damaged parts.
The new Remover Tools from Schwaben leave your knuckles and expensive parts intact.
The new Exhaust Hanger Removal Tool has a slim profile for work in tight areas, easily pulling off hangers from behind. Steering and Suspension Ball Joint Separators offer a combined 12mm to 80mm jaw opening range.
New rugged 3/8” drive Schwaben E-Socket Sets are also available.
Old Mar 10, 2015 | 11:46 AM
ECSTuning's Avatar
2012 SLS AMG
Schwaben Service Carts!!
The average home mechanic might not even realize the benefit of having a sturdy, hand-height shelf to place tools on in the heat of a project.
Instead of carelessly leaving tools on the ground or mixed up in a pile, Schwaben Service Carts bring the professionalism of a reliable mechanic's cart to your own garage.
Three series of carts are offered, each featuring a stunning, durable high-gloss powder-coated finish, chrome plated steel handles, and large 4" casters.
Heavy-duty Deluxe units are also available, with a third product adding a locking top lid and drawer.
