Introducing New Rear Air Spring for the '04-'13 V-Class
The Air Spring -- A-2801 -- fits either the left or right rear of the Viano, Valente (Australia) and V-Class (Japan) and replaces OE Part Numbers:
6393280101
6393280201
6393280301
The Arnott spring is assembled in the U.S. with a multi-ply ContiTech air sleeve, heavy-duty crimping rings, and features a high-impact resin upper mount and lower piston along with a new airline fitting for a fast installation.
A-2801 retails for $129 and is backed by Arnott's Limited Lifetime Warranty.
Features:
* Economical Design Replaces the OE Air Spring
* Pre-Assembled for a Fast and Easy Installation
* Resin Upper Cap & Lower Piston
* Multi-Ply ContiTech Air Spring Bladder
* Engineered & Assembled in the USA
* Limited Lifetime Warranty
Additional Aftermarket Innovations for the Mercedes-Benz
The featured new aftermarket Air Spring for the V-Class Mercedes-Benz is a high-quality, cost-effective solution for Mercedes-Benz owners concerned about failing OE air suspension parts leaving them stranded with expensive and recurring maintenance problems. 'The Arnott Advantage' adds exceptional value to some of the most sophisticated air suspension components available. In keeping with the Mercedes-Benz tradition of quality and innovation, Arnott continues to introduce its own products and designs to replace failing Mercedes-Benz original equipment. See Arnott's impressive array of additional, innovative new and remanufactured aftermarket replacement parts for Mercedes-Benz Here.
