OmniVision Sensor Delivers Superior Night Vision
The ViewClear 70 is a dual-channel dash cam (4K front + 2.5K rear), both with HDR, and it comes with 5.8GHz Wi-Fi 6 for smooth connectivity. What makes it stand out is how it handles night driving. The front camera uses Sony's IMX678 with STARVIS 2, which helps reduce noise and motion blur, while the rear camera is powered by an OmniVision sensor built for low-light conditions.
The OmniVision sensor brings two innovative technologies that optimize performance for low-light driving.
- In low-light conditions, PureCel® Plus pixel technology picks up more light by significantly enhancing sensor sensitivity and the maximum number of electrons each pixel can store, allowing pixels to capture more photons in dark environments, which boosts low-light performance with higher dynamic range.
- Nyxel® NIR (Near Infrared) Sensor Technology achieves up to threefold quantum efficiency improvements, capturing more usable light signals in the near-infrared spectrum to produce sharp, bright images and deliver optimum image data, enabling image sensors to see better and farther while using less power.
In low-light conditions, the pairing of the VC70's IMX678 and OmniVision sensors captures greater detail with less noise, ensuring you won't miss anything when it matters most. On dark roads, the VC70 can be a truly helpful companion.
🚗Discount info:
Redtiger's Labor Day Sale is live — sitewide discounts of up to 40%!
👉 https://redtigercam.com/pages/labor-day-special
The VC70 is currently 30% OFF!
