JBSPEED/Racing Dash LED License Plate Light!!SUPER BRIGHT!!Error FREE!!!
#152
2010 c63 AMG
First you gotta remove the inside trunk liner, theres two torx screws on the inside right next to the handle. Remove them. Than on the outside, two more torx screws. Than gently pull the chrome trunk trim off, theres about 4 clips. After all that is removed, you can reach in the trunk lid, and unclip the stock lights. Plug the new ones in, and reinstall everything.. Best i can do. Search for the thread about DIY reverse camera install. All the info is there to remove all these parts. Now heres a couple pic with my trusty iphone.
Dont mind the dirty car.. Weather is horrible here
-Walter
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
-Walter
Can you please indicate where the other 2 torx screws are? There are one torx to the left of the hand, one to the right, where is the other two?
Can you indicate it on a picture? Im confused.
I dont want to have to remoe like 20 screws.
Thanks.
-Leon
#153
C63, Grigio Medio E46 M3
after you remove the inside trunk lid liner, look into the trunk lid, where the handle is. There are two more torx on both sides of the handle that have to be removed..
![](https://farm4.static.flickr.com/3022/2704850177_a04ec09440_o.jpg)
![](https://farm4.static.flickr.com/3008/2704850363_7f2d5caf65_o.jpg)
![](https://farm4.static.flickr.com/3171/2705671948_59c69deda9_o.jpg)
![](https://farm4.static.flickr.com/3004/2704849591_a95cffcdbb_o.jpg)
Props to Rick hunter for these pics..
#155
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
there is no point to spend $65 bucks on these when all you need to spend is $8 bucks and replace the bulbs with Polargs or with LEDs for $30
The bulbs are placed easily on the w204 and there is NO NEED to buy whole new housing, FIY
#165
Flying Spur
For those of you that are saying bulbs are easier to install and cheaper, yes your are right, BUT, in the last 6 months i've had to replace the bulbs twice because they start to flash over time then go out. I'm going to try these next, just seems like a big PITA to get them in
![action](https://mbworld.org/forums/images/smilies/action1.gif)
