Veloce Performance Big Brake Specials!
#77
Just like with more power...... there never is enough. You can never have enough braking, and it can always be better.
With that in mind, we have always sought out partnerships with the best brake manufacturers in the world. We were exclusively carrying Brembo, but we ran across WP Pro Systems and decided to give them a try. All I can say is WOW! Incredible performance! Incredible products! Incredible pricing!
Take a look at the quality of the build, and the materials used. Forged vs cast. Weight advantages and a lifetime warranty, and the list goes on. Put it all together and you will come to the same conclusion I did..... these are amazing brakes... What sealed the deal for me was the first time I stepped on the brakes, and it will for you too. Packages are available with 4, 6, 8 and 12 piston calipers!
Take a look at some of the applications and kits, and let us put a custom package together for you..... and you won't believe how good the price is!! I will be offering some incredible savings on these packages through 4/30/10, so if you want to take the braking performance of your MB/AMG to the next level, now is the time
#80
124 320ce amg widebody twin turbo, the nail
i am currently in the process of putting performance kits together, basicly offering larger disks that can be paired with calipers from other mercs(or other cars for that matter, porch and audi are possibe)
i will be offering two piece front disks for 124 129 203 203 107 and possibly others, the disk pad areas will depend on which caliper the customer wants to use ie, the six pots biggest type fom the black series cars with 65mm pad area ,or the simerller looking but smaller ones from the clk 55 amg with 50 odd mm of pad area, or disks to fit the smaller four pot calipers.
prices will probbably be too steep for usa customers due to you guys getting everything cheeper than us! but disks will be approx 450gbp
#82
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
I think the PM prices comes more from the manufacturers that may not want discounted prices posted.
There are several available options that require 19" wheels.
F/8 piston calipers, 388mm rotors
R/6 piston calipers, 360mm rotors
$5500 delivered
F/12 piston, 388mm rotors
R/6 piston, 360mm rotors
$8240 delivered
Let me know when you want them delivered!
$5500 delivered
$8240 delivered
#84
2003 S210 3.8L Brabus wagon
Esh:
We are also a Brembo dealer, and after having driven similar cars equipped with Brembo and WP Pro, I really liked the WP's better. For a 210 E class:
Brembo: F/6 piston 355mm rotor, R/4 piston 345mm rotor... $7000+shipping
WP Pro: F/8 piston 360mm rotor, R/6 piston 360mm rotor... $4700 delivered
#88
SL55 AMG
I spoke with the company yesterday about this and they said that they used to make them and they would again if the demand is there. Their rotors that work with their calipers are wider than our stock rotors in order to work better with the heat.
They said that when they produced them, they were $1000 for a pair. How does that compare with EvoSport?
#90
the closer you can do to $600 a pair for the front the better market - the cost to make these is not that high - many of these rotors are sourced from places like KVR, Brembo, AP, or Alcon - so the supply side can be competative. I think for a set front and rear 2 piece lightweight factory replacement should be right around a grand or so; this is very possible I would think since the demand side spans through several models of MB cars (all AMG 55 cars) and the supply side can be made sompetative.
